2023-03-14 20:57:34 +00:00
.github/workflows fix: first working version 2023-03-14 20:57:34 +00:00
build Installer script for updating CVE list 2022-12-29 19:07:53 +01:00
test_db@d01cb62fcf fix: adding localhost host 2023-03-14 20:23:07 +00:00
mysqltuner.pl Update Vulnerabilities list 2023-03-11 07:48:00 +01:00
README.md ERROR 1054 2023-02-02 08:22:07 +01:00
vulnerabilities.csv Update Vulnerabilities list 2022-12-29 05:13:02 +01:00
  • MariaDB 10.6 (full support)
*** MINIMAL REQUIREMENTS ***
