MySQL name resolution only applies to TCP/IP connections ( see lines 504 and 599 of mysql-server/sql/sql_connect.cc ). Thus there is no reason to test, or suggest, setting skip_name_resolve if skip_networking exists and is turned on. |
| build | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| mysqltuner.png | ||
| README.fr.md | ||
| README.it.md | ||
| README.ru.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
- MySQL 5.7 (full support)
- MySQL 5.6 (full support)
- MySQL 5.5 (full support)
- MariaDB 10.1 (full support)
- MariaDB 10.0 (full support)
Security recommandations
- Fedora Core 23 / MySQL 5.6
- Fedora Core 23 / MySQL 5.7
- vagrant up
- Start vagrant
- vagrant up
