Files changed: A examples/github/result/mariadb/10.2/ifs_ALL_PLUGINS.csv A examples/github/result/mariadb/10.2/ifs_APPLICABLE_ROLES.csv A examples/github/result/mariadb/10.2/ifs_CHARACTER_SETS.csv A examples/github/result/mariadb/10.2/ifs_CHECK_CONSTRAINTS.csv A examples/github/result/mariadb/10.2/ifs_CLIENT_STATISTICS.csv A examples/github/result/mariadb/10.2/ifs_COLLATIONS.csv A examples/github/result/mariadb/10.2/ifs_COLLATION_CHARACTER_SET_APPLICABILITY.csv A examples/github/result/mariadb/10.2/ifs_COLUMNS.csv A examples/github/result/mariadb/10.2/ifs_COLUMN_PRIVILEGES.csv A examples/github/result/mariadb/10.2/ifs_ENABLED_ROLES.csv A examples/github/result/mariadb/10.2/ifs_ENGINES.csv A examples/github/result/mariadb/10.2/ifs_EVENTS.csv A examples/github/result/mariadb/10.2/ifs_FILES.csv A examples/github/result/mariadb/10.2/ifs_GEOMETRY_COLUMNS.csv A examples/github/result/mariadb/10.2/ifs_GLOBAL_STATUS.csv A examples/github/result/mariadb/10.2/ifs_GLOBAL_VARIABLES.csv A examples/github/result/mariadb/10.2/ifs_INDEX_STATISTICS.csv A examples/github/result/mariadb/10.2/ifs_INNODB_BUFFER_PAGE.csv A examples/github/result/mariadb/10.2/ifs_INNODB_BUFFER_PAGE_LRU.csv A examples/github/result/mariadb/10.2/ifs_INNODB_BUFFER_POOL_STATS.csv A examples/github/result/mariadb/10.2/ifs_INNODB_CMP.csv A examples/github/result/mariadb/10.2/ifs_INNODB_CMPMEM.csv A examples/github/result/mariadb/10.2/ifs_INNODB_CMPMEM_RESET.csv A examples/github/result/mariadb/10.2/ifs_INNODB_CMP_PER_INDEX.csv A examples/github/result/mariadb/10.2/ifs_INNODB_CMP_PER_INDEX_RESET.csv A examples/github/result/mariadb/10.2/ifs_INNODB_CMP_RESET.csv A examples/github/result/mariadb/10.2/ifs_INNODB_FT_BEING_DELETED.csv A examples/github/result/mariadb/10.2/ifs_INNODB_FT_CONFIG.csv A examples/github/result/mariadb/10.2/ifs_INNODB_FT_DEFAULT_STOPWORD.csv A examples/github/result/mariadb/10.2/ifs_INNODB_FT_DELETED.csv A examples/github/result/mariadb/10.2/ifs_INNODB_FT_INDEX_CACHE.csv A examples/github/result/mariadb/10.2/ifs_INNODB_FT_INDEX_TABLE.csv A examples/github/result/mariadb/10.2/ifs_INNODB_LOCKS.csv A examples/github/result/mariadb/10.2/ifs_INNODB_LOCK_WAITS.csv A examples/github/result/mariadb/10.2/ifs_INNODB_METRICS.csv A examples/github/result/mariadb/10.2/ifs_INNODB_MUTEXES.csv A examples/github/result/mariadb/10.2/ifs_INNODB_SYS_COLUMNS.csv A examples/github/result/mariadb/10.2/ifs_INNODB_SYS_DATAFILES.csv A examples/github/result/mariadb/10.2/ifs_INNODB_SYS_FIELDS.csv A examples/github/result/mariadb/10.2/ifs_INNODB_SYS_FOREIGN.csv A examples/github/result/mariadb/10.2/ifs_INNODB_SYS_FOREIGN_COLS.csv A examples/github/result/mariadb/10.2/ifs_INNODB_SYS_INDEXES.csv A examples/github/result/mariadb/10.2/ifs_INNODB_SYS_SEMAPHORE_WAITS.csv A examples/github/result/mariadb/10.2/ifs_INNODB_SYS_TABLES.csv A examples/github/result/mariadb/10.2/ifs_INNODB_SYS_TABLESPACES.csv A examples/github/result/mariadb/10.2/ifs_INNODB_SYS_TABLESTATS.csv A examples/github/result/mariadb/10.2/ifs_INNODB_SYS_VIRTUAL.csv A examples/github/result/mariadb/10.2/ifs_INNODB_TABLESPACES_ENCRYPTION.csv A examples/github/result/mariadb/10.2/ifs_INNODB_TABLESPACES_SCRUBBING.csv A examples/github/result/mariadb/10.2/ifs_INNODB_TRX.csv A examples/github/result/mariadb/10.2/ifs_KEYWORDS.csv A examples/github/result/mariadb/10.2/ifs_KEY_CACHES.csv A examples/github/result/mariadb/10.2/ifs_KEY_COLUMN_USAGE.csv A examples/github/result/mariadb/10.2/ifs_PARAMETERS.csv A examples/github/result/mariadb/10.2/ifs_PARTITIONS.csv A examples/github/result/mariadb/10.2/ifs_PLUGINS.csv A examples/github/result/mariadb/10.2/ifs_PROCESSLIST.csv A examples/github/result/mariadb/10.2/ifs_PROFILING.csv A examples/github/result/mariadb/10.2/ifs_REFERENTIAL_CONSTRAINTS.csv A examples/github/result/mariadb/10.2/ifs_ROUTINES.csv A examples/github/result/mariadb/10.2/ifs_SCHEMATA.csv A examples/github/result/mariadb/10.2/ifs_SCHEMA_PRIVILEGES.csv A examples/github/result/mariadb/10.2/ifs_SESSION_STATUS.csv A examples/github/result/mariadb/10.2/ifs_SESSION_VARIABLES.csv A examples/github/result/mariadb/10.2/ifs_SPATIAL_REF_SYS.csv A examples/github/result/mariadb/10.2/ifs_SQL_FUNCTIONS.csv A examples/github/result/mariadb/10.2/ifs_STATISTICS.csv A examples/github/result/mariadb/10.2/ifs_SYSTEM_VARIABLES.csv A examples/github/result/mariadb/10.2/ifs_TABLES.csv A examples/github/result/mariadb/10.2/ifs_TABLESPACES.csv A examples/github/result/mariadb/10.2/ifs_TABLE_CONSTRAINTS.csv A examples/github/result/mariadb/10.2/ifs_TABLE_PRIVILEGES.csv A examples/github/result/mariadb/10.2/ifs_TABLE_STATISTICS.csv A examples/github/result/mariadb/10.2/ifs_TRIGGERS.csv A examples/github/result/mariadb/10.2/ifs_USER_PRIVILEGES.csv A examples/github/result/mariadb/10.2/ifs_USER_STATISTICS.csv A examples/github/result/mariadb/10.2/ifs_VIEWS.csv A examples/github/result/mariadb/10.2/ifs_user_variables.csv A examples/github/result/mariadb/10.2/result.json A examples/github/result/mariadb/10.2/result.txt |
| .github/workflows | ||
| build | ||
| examples/github/result/mariadb/10.2 | ||
| templates | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| mtlogo.png | ||
| mysqltuner.png | ||
| README.fr.md | ||
| README.it.md | ||
| README.ru.md | ||
| renovate.json | ||
| SECURITY.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
MySQL 5.7 (full support)
MariaDB 10.11 (full support)
MariaDB 10.10 (full support)
MariaDB 10.9 (full support)
MariaDB 10.8 (full support)
MariaDB 10.7 (full support)
MariaDB 10.6 (full support)
MariaDB 10.5 (full support)
MariaDB 10.4 (full support)
MariaDB 10.3 (full support)
RockDB
Archive
Spider
ColummStore
TokuDB
XtraDB
Connect
Hi directadmin user!
- A MySQL server installation
- Fedora Core 30 / Docker
- Fork this Github project
- Make a new branch
- Make your changes
- Push it back to your repo
