| .github/workflows | ||
| build | ||
| examples/github/result | ||
| templates | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| Dockerfile | ||
| FEATURES.md | ||
| INTERNALS.md | ||
| JenkinsFile | ||
| Makefile | ||
| mtlogo.png | ||
| mysqltuner.png | ||
| README.fr.md | ||
| README.it.md | ||
| README.ru.md | ||
| renovate.json | ||
| SECURITY.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
- Please join us on our issue tracker at GitHub tracker.
- Paid support for LightPath here: jmrenouard@lightpath.fr
Test result are available here:
MySQL 8.0, 8.2, 8.3 (full support)
Percona Server 8.0, 8.2, 8.3 (full support)
MariaDB 10.4, 10.5, 10.6, 10.11, 11.0, 11.1, 11.2 (full support)
MySQL 8.1 (not supported, deprecated version)
Percona Server 5.7 (not supported, deprecated version)
MySQL 5.7 (not supported, deprecated version)
MySQL 5.6 and earlier (not supported, deprecated version)
Percona Server 5.6 (not supported, deprecated version)
MariaDB 10.7, 10.8, 10.9, 10.10 (not supported, deprecated version)
MariaDB 10.3 and earlier (not supported, deprecated version)
MariaDB 5.5 (not supported, deprecated version)
- Successfully run MySQLtuner across WSL2 (Windows Subsystem Linux)
- Cloud based is not supported at this time (Help wanted! GCP, AWS, Azure support requested)
- NDB is not supported feel free to create a Pull Request
- Archive
- Spider
- ColummStore
- Connect
MyISAM is too old and no longer active
RockDB is not maintained anymore
TokuDB is not maintained anymore
XtraDB is not maintained anymore
- Unrestricted read access to the MySQL server OS root access recommended for MySQL < 5.1
Hi directadmin user!
cd mariadb-sys-master
Performance schema setup
max-digest-length=2048
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
- A MySQL server installation
SHOW DATABASES,SHOW VIEW
ON *.*
- Fedora Core 30 / Docker
- Fork this Github project
- Make a new branch
- Make your changes
- Push it back to your repo
