| build | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| README.ru.md | ||
| template_example.tpl | ||
| USAGE.md | ||
- MySQL 5.7 (partial support)
- MySQL 5.6 (full support)
- MariaDB 10.0 (full support)
- MySQL 5.5 (full support)
- MySQL 5.1 (full support)
MySQLTuner contains a Vagrant configuration for test purpose and development
- Install VirtualBox and Vagrant https://www.virtualbox.org/wiki/Downloads https://www.vagrantup.com/downloads.html
- Clone repository git clone https://github.com/major/MySQLTuner-perl.git
- Install Vagrant plugins vagrant-hostmanager and vagrant-vbguest vagrant plugin install vagrant-hostmanager vagrant plugin install vagrant-vbguest
- Add Fedora Core 23 box for official Fedora Download Website vagrant box add --name fc23 https://download.fedoraproject.org/pub/fedora/linux/releases/23/Cloud/x86_64/Images/Fedora-Cloud-Base-Vagrant-23-20151030.x86_64.vagrant-virtualbox.box
- Create a data directory mkdir data
- Rename Vagrantfile_MariaDB10.0 into Vagrantfile cp MySQLTuner-perl/Vagrant/Vagrantfile_for_MariaDB10.0 Vagrantfile
- Start vagrant vagrant up
