Jean-Marie Renouard 10abb0c3d0 Updated .gitignore
2022-07-09 19:32:54 +02:00
.github/workflows New workflow 2022-04-04 02:32:15 +02:00
.gitignore Updated .gitignore 2022-07-09 19:32:54 +02:00
mysqltuner.pl Something broken when correcting "incorrectly reports roles as users without passwords #598" #600 2022-06-22 18:41:53 +02:00
README.md Adding AHA section for HTML generation 2022-03-11 14:38:08 +01:00
USAGE.md Update USAGE.md 2022-02-08 00:33:33 +01:00
vulnerabilities.csv Update Vulnerabilities list 2022-02-04 16:01:22 +01:00
  • MariaDB 10.6 (full support)
*** MINIMAL REQUIREMENTS ***
