2016-12-12 14:19:49 +03:00
mysqltuner.pl fix check innodb_file_per_table with skip-innodb 2016-12-12 14:19:49 +03:00
README.md Fix typos 2016-11-05 14:27:54 +00:00
vulnerabilities.csv Update vulnerabilities list 2016-11-28 17:52:13 +01:00
MySQLTuner is maintained and indicator collect is increasing week after week supporting a lot of configuration such as Galera Cluster, TokuDB,        Performance schema, Linux OS metrics, InnoDB, MyISAM, Aria, ...
