2021-11-23 16:00:58 +01:00
.github/workflows Create exec.yml 2021-07-05 08:45:01 +02:00
mysqltuner.pl Wrong recommendation "thread_pool_size between 16 and 36 for InnoDB usage" for Percona Server 2021-10-16 17:07:14 +02:00
README.md #574 script modified with CR end of line 2021-11-23 16:00:58 +01:00
USAGE.md Update Vulnerabilities list 2021-10-15 13:56:27 +02:00
vulnerabilities.csv Update Vulnerabilities list 2021-09-27 12:28:31 +02:00
  • MySQL 5.6 (full support, no more MySQL support)
  • MariaDB 10.2 (full support)
  • MariaDB 10.1 (full support, no more MariaDB support)
  • MariaDB 10.0 (full support, no more MariaDB support)
*** MINIMAL REQUIREMENTS ***
