Jean-Marie Renouard 1ecb2e9854 Update Vulnerabilities list
Indenting mysqltuner
Update Usage information
2021-09-27 12:08:36 +02:00
.github/workflows Create exec.yml 2021-07-05 08:45:01 +02:00
build Merge done 2021-09-27 12:07:52 +02:00
Vagrant clean end line 2021-09-27 11:55:22 +02:00
.perltidy clean end line 2021-09-27 11:55:22 +02:00
.travis.yml travis: add percona supported versions 2021-02-01 15:11:34 +11:00
mysqltuner.pl clean end line 2021-09-27 11:55:22 +02:00
README.md Merge done 2021-09-27 12:07:52 +02:00
USAGE.md Update Vulnerabilities list 2021-09-27 12:08:36 +02:00
vulnerabilities.csv Update Vulnerabilities list 2021-08-25 12:03:29 +02:00
  • MySQL 5.6 (full support, no more MySQL support)
  • MariaDB 10.2 (full support)
  • MariaDB 10.1 (full support, no more MariaDB support)
  • MariaDB 10.0 (full support, no more MariaDB support)
*** MINIMAL REQUIREMENTS ***
  • Click Create pull request to open a new pull request ======= MySQLTuner-perl ==== Build Status - Master Project Status Project Status Average time to resolve an issue Percentage of open issues GPL License
Question: What's minimum privileges needed by a specific mysqltuner user in database for MySQL 8 or MariaDB 10.5 ?
    mysql>GRANT SELECT, PROCESS,EXECUTE, REPLICA MONITOR,SHOW DATABASES,SHOW VIEW ON *.* TO 'mysqltuner'@'localhost' identified by pwd1234;
