2014-02-22 01:39:01 +01:00
mysqltuner.pl Merge d07b504f8c into 18eed21ecd 2014-02-22 01:39:01 +01:00
README.md Converted README from text to Markdown. 2014-02-21 10:52:51 -06:00
  • MySQL 6.0 (partial support)
wget mysqltuner.pl
* OS and OS version
* Exact MySQL version
* The full text of the error
