Jean-Marie Renouard 21d797b065
Merge pull request #392 from unreturned/patch-2
Minor fix undefined value
2018-07-27 10:26:31 +02:00
build Ticket #383 Minor accessing undefined variable bug to fix eventually 2018-06-29 12:16:30 +02:00
.travis.yml Update travis 2018-07-06 21:10:56 +03:00
INTERNALS.md Update INTERNALS.md 2018-03-19 17:01:22 +01:00
mysqltuner.pl Minor fix undefined value 2018-07-26 23:00:04 +03:00
README.md Update README.md 2018-07-19 17:01:12 +02:00
USAGE.md Update staff 2018-04-26 14:15:59 +02:00
vulnerabilities.csv New vulnerabilities list 2018-04-26 14:27:33 +02:00
  • MariaDB 10.2 (full support)
