Jean-Marie Renouard 235cc4e0f9
Merge pull request #756 from jmrenouard/master
Refactoring format
2024-02-07 01:11:00 +01:00
Makefile Last updates 2023-09-09 12:08:45 +02:00
mysqltuner.pl Adding secure check when missing value 2024-02-07 00:07:41 +01:00
README.md REfactoring format 2024-02-07 01:09:53 +01:00
README.ru.md remove innodb_stats_on_metadata mentions in Readme 2023-11-30 16:00:39 +01:00
USAGE.md Generate 2.5.2 sub version at 2024-02-06T17:58:35+01:00 2024-02-06 17:58:35 +01:00
v2.5.2.txt Adding shebang comment for auto execution 2024-02-06 18:35:38 +01:00
vulnerabilities.csv Generate CVE list at 2024-02-06T17:59:02+01:00 2024-02-06 18:00:04 +01:00
Anurag's GitHub stats
  • MySQL 8.0, 8.2, 8.3 (full support)
  • Percona Server 8.0, 8.2, 8.3 (full support)
  • MariaDB 10.4, 10.5, 10.6, 10.11, 11.0, 11.1, 11.2 (full support)
  • MySQL 8.1 (not supported, deprecated version)
  • Percona Server 5.7 (not supported, deprecated version)
  • MySQL 5.7 (not supported, deprecated version)
  • MariaDB 10.7, 10.8, 10.9, 10.10 (not supported, deprecated version)
  • MariaDB 10.3 and earlier (not supported, deprecated version)
  • RockDB is not maintained anymore
  • TokuDB is not maintained anymore
  • XtraDB is not maintained anymore
  • Unrestricted read access to the MySQL server OS root access recommended for MySQL < 5.1
cd mariadb-sys-master
Performance schema setup
max-digest-length=2048
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
  • A MySQL server installation
 SHOW DATABASES,SHOW VIEW
 ON *.*
