2012-04-26 15:49:29 +03:00
mysqltuner.pl Add DirectAdmin support. Also tested on DirectAdmin v 1.40.3 on Debian 6 - 64 bits #17 2012-04-26 15:49:29 +03:00
README Expanded README 2009-09-16 02:12:48 +00:00
----- MySQLTuner-perl -----
MySQLTuner is a script written in Perl that allows you to review a MySQL installation quickly and make adjustments to increase performance and stability.  The current configuration variables and status data is retrieved and presented in a brief format along with some basic performance suggestions.
	* MySQL 3.23, 4.0, 4.1, 5.0, 5.1 (full support)
	* MySQL 5.4 (not fully tested, partially supported)
	* MySQL 6.0 (partial support)
	* Perl 5.6 or later
	* Unix/Linux based operating system (tested on Linux, BSD variants, and Solaris variants)
	* Windows is not supported at this time
	* Unrestricted read access to the MySQL server (OS root access recommended for MySQL < 5.0)
Please review the FAQ section below.
*WARNING*
	It is extremely important for you to fully understand each change
	you make to a MySQL database server.  If you don't understand portions
	of the script's output, or if you don't understand the recommendations,
	you should consult a knowledgeable DBA or even a system administrator
	that you trust.  Always test your changes on staging environments, and
	always keep in mind that improvements in one area can negatively affect
	MySQL in other areas.
*WARNING*
----- Download/Installation -----
You can download the entire repository by using 'git clone' followed by the cloning URL above.  The simplest and shortest method is:
	wget mysqltuner.pl
----- FAQ -----
Literally - no.  MySQLTuner is a read only script.  It won't write to any configuration files, change the status of any daemons, or call your mother to wish her a happy birthday.  It will give you an overview of your server's performance and make some basic recommendations about improvements that you can make after it completes.  Make sure you read the warning above prior to following any recommendations.
MySQLTuner will not replace your DBA in any form or fashion.  If your DBA constantly takes your parking spot and steals your lunch from the fridge, then you may want to consider it - but that's your call.
The script will try its best to log in via any means possible.  It will check for ~/.my.cnf files, Plesk password files, and empty password root logins.  If none of those are available, then you'll be prompted for a password.  If you'd like the script to run in an automated fashion without user intervention, then create a .my.cnf file in your home directory which contains:
Once you create it, make sure it's owned by your user and the mode on the file is 0600.  This should prevent the prying eyes from getting your database login credentials under normal conditions.  If a T-1000 shows up in a LAPD uniform and demands your database credentials, you won't have much of an option.
These kinds of things are bound to happen.  Here are the details I need from you in order to research the problem thoroughly:
	* OS and OS version
	* Exact MySQL version
	* The full text of the error
Once you get those, join the Google Group and drop your issue to the list:
	http://groups.google.com/group/mysqltuner-talk
