Major Hayden 35955db67f Merge pull request #19 from DanBUK/master
Swap position of innodb buffer pool size and data size arguments
2014-02-21 19:13:46 -06:00
mysqltuner.pl Merge pull request #19 from DanBUK/master 2014-02-21 19:13:46 -06:00
README.md Converted README from text to Markdown. 2014-02-21 10:52:51 -06:00
  • MySQL 6.0 (partial support)
wget mysqltuner.pl
* OS and OS version
* Exact MySQL version
* The full text of the error
