Jean-Marie Renouard 38dbf6e6ec Merge pull request #214 from jfcoz/innodb_space
add innodb when innodb_file_per_table is ON
2016-06-02 14:55:04 +02:00
INTERNALS.md enought to enough 2016-04-26 15:29:49 -06:00
mysqltuner.pl add innodb when innodb_file_per_table is ON 2016-06-02 09:40:42 +02:00
README.md Update README.md 2016-05-17 12:13:07 +02:00
vulnerabilities.csv Update vulnerabilies list 2016-05-04 16:37:26 +02:00
  • MySQL 5.7 (partial support)
