Major Hayden 393cd62adb Merge pull request #71 from cloos/linux-memory
fix fetching memory values on non-english Linux systems
2015-06-16 07:46:10 -05:00
mysqltuner.pl fix fetching memory values on non-english Linux systems 2015-06-16 14:26:08 +02:00
README.md Adding partiel suport for MySQL 5.5 and MySQL 5.6 2015-06-15 16:25:48 +02:00
  • MySQL 5.5 (partial support)
  • MySQL 5.6 (partial support)
  • MySQL 6.0 (partial support)
* OS and OS version
* Exact MySQL version
* The full text of the error
