Jean-Marie Renouard 396940f87c
Merge pull request #643 from jmrenouard/examples-mariadb-10.6-2023-03-23T16-39-42Z
Examples mariadb 10.6 2023 03 23 t16 39 42 z
2023-03-23 17:52:09 +01:00
.github/workflows Renaning Branch for MAriaDB Examples 2023-03-23 16:34:58 +00:00
examples/github/result Merge pull request #643 from jmrenouard/examples-mariadb-10.6-2023-03-23T16-39-42Z 2023-03-23 17:52:09 +01:00
.gitignore fix: Error durig exec 2023-03-23 14:51:29 +00:00
mysqltuner.pl Merge pull request #633 from longradix/master 2023-03-23 10:40:59 +01:00
README.md fix: Markdown rules fixed 2023-03-23 10:02:02 +00:00
vulnerabilities.csv Updates CVS and docs 2023-03-22 16:34:10 +01:00
  • MariaDB 10.9 (full support)
  • MariaDB 10.8 (full support)
  • MariaDB 10.7 (full support)
  • MariaDB 10.6 (full support)
  • A MySQL server installation
