Jean-Marie Renouard 3d1c6cf745 Update README.md
2015-08-19 15:16:29 +02:00
CONTRIBUTING.md Update CONTRIBUTING.md 2015-08-19 14:58:07 +02:00
INTERNALS.md Update INTERNALS.md 2015-08-19 14:38:28 +02:00
mysqltuner.pl Pertidy code + rearrange ocde 2015-08-19 14:45:24 +02:00
README.md Update README.md 2015-08-19 15:16:29 +02:00
  • MySQL 5.7 (partial support)
  • MySQL 5.1 (full support)
