Jean-Marie Renouard 3d8b33e51d Merge pull request #299 from greg-kennedy/patch-1
Do not test skip_name_resolve if skip_networking is ON
2017-02-13 13:25:08 +01:00
build Update git ignore list 2017-02-07 07:11:39 +01:00
INTERNALS.md Add advice for performance schema 2017-02-07 06:56:17 +01:00
mysqltuner.pl Do not test skip_name_resolve if skip_networking is ON 2017-02-08 11:10:48 -06:00
README.md Some Markdown typos and fixes 2017-01-24 01:19:36 +01:00
USAGE.md update USAGE information 2017-02-07 07:03:19 +01:00
vulnerabilities.csv Update vulnerabilities list 2017-02-07 06:27:34 +01:00
Security recommandations
