2023-03-18 17:57:06 +01:00
.github/workflows feat: try to auto commit result into repo 2023-03-18 17:57:06 +01:00
build feat: try to auto commit result into repo 2023-03-18 17:57:06 +01:00
test_db@d01cb62fcf fix: adding localhost host 2023-03-14 20:23:07 +00:00
mysqltuner.pl feat: try to auto commit result into repo 2023-03-18 17:57:06 +01:00
README.md ERROR 1054 2023-02-02 08:22:07 +01:00
vulnerabilities.csv feat: try to auto commit result into repo 2023-03-18 17:57:06 +01:00
  • MariaDB 10.6 (full support)
*** MINIMAL REQUIREMENTS ***
