2015-07-13 16:18:25 +02:00
misc Documenting a bit 2015-06-21 16:09:00 -04:00
CONTRIBUTING.md Adding a small CONTRIBUTING file 2015-06-16 15:20:36 +02:00
mysqltuner.pl Fix #83 efficiency calculations values for write/read innodb buffer 2015-07-13 16:18:25 +02:00
README.md README format errorswq 2015-06-16 15:45:34 +02:00
USAGE.md Adding information about Max and Reached memory for MySQL process. 2015-07-02 00:19:28 +02:00
  • MySQL 5.5 (partial support)
  • MySQL 5.6 (partial support)
  • MySQL 6.0 (partial support)
* OS and OS version
* Exact MySQL version
* The full text of the error
