Jean-Marie Renouard 55c7aa96bc Merge pull request #284 from i5513/patch-1
Allow to connect via socket with not default port
2016-12-21 00:09:26 +01:00
mysqltuner.pl Allow to connect via socket with not default port 2016-12-20 10:35:41 +01:00
README.md Fix typos 2016-11-05 14:27:54 +00:00
vulnerabilities.csv Update vulnerabilities list 2016-11-28 17:52:13 +01:00
MySQLTuner is maintained and indicator collect is increasing week after week supporting a lot of configuration such as Galera Cluster, TokuDB,        Performance schema, Linux OS metrics, InnoDB, MyISAM, Aria, ...
