Jean-Marie Renouard 57e2cba90f Update Vulnerabilities list
Indenting mysqltuner
Update Usage information
2019-09-25 20:07:18 +00:00
build update CVE to include Percona 2019-08-16 11:42:54 +02:00
Vagrant Create Vagrantfile_for_MariaDB10.4 2019-09-25 20:22:16 +02:00
.gitignore Refresh config. Vagrant 2019-07-07 09:58:02 +02:00
.travis.yml Add test env for MariaDB 10.4 (GA) 2019-07-25 12:38:43 +02:00
INTERNALS.md Update INTERNALS.md #419 2019-01-07 11:01:54 +01:00
mysqltuner.pl Update Vulnerabilities list 2019-09-25 20:05:45 +00:00
README.md Add --host to minimal usage locally example 2019-07-13 02:01:22 +02:00
runAudit.sh New script for running remote audit and generate HTML report 2018-09-24 16:12:40 +02:00
txt2html.pl New script for running remote audit and generate HTML report 2018-09-24 16:12:40 +02:00
USAGE.md Update Vulnerabilities list 2019-09-25 20:05:45 +00:00
vulnerabilities.csv Update Vulnerabilities list 2019-09-25 20:07:18 +00:00
  • MariaDB 10.2 (full support)
