| build | ||
| Vagrant | ||
| .perltidy | ||
| bashrc | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| mysqltuner.png | ||
| README.fr.md | ||
| README.it.md | ||
| README.ru.md | ||
| runAudit.sh | ||
| sync.sh | ||
| template_example.tpl | ||
| txt2html.pl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
Test result are avalaible here: Travis CI/MySQLTuner-perl
- MySQL 8 (partial support, password checks don't work)
- MySQL 5.7 (full support)
- MySQL 5.6 (full support)
- MariaDB 10.3 (full support)
- MariaDB 10.2 (full support)
- MariaDB 10.1 (full support)
- MariaDB 10.0 (full support, 6 last month support)
- Percona Server 5.7 (full support)
- MySQL 3.23, 4.0, 4.1, 5.0, 5.1, 5.5 (partial support - deprecated version)
Hi directadmin user!
- Fedora Core 23 / MySQL 5.6
- Fedora Core 23 / MySQL 5.7
- vagrant up
- Start vagrant
- vagrant up
