Jean-Marie Renouard 5bc816e88d
Merge pull request #709 from paskal/master
Clarify that innodb_stats_on_metadata is actual only in MySQL<=5.6
2023-07-27 14:56:37 +02:00
.gitignore Adding detection of non primary key tables 2023-06-22 23:00:28 +02:00
FEATURES.md Update code and CVEs 2023-07-06 08:19:29 +02:00
INTERNALS.md Update INTERNALS.md 2023-06-19 10:28:55 +02:00
mysqltuner.pl Changed InnoDb to InnoDB for consistency on the report. 2023-07-27 10:23:00 +12:00
README.md clarify that innodb_stats_on_metadata is actual only in MySQL<=5.6 2023-07-25 22:52:58 +02:00
README.ru.md clarify that innodb_stats_on_metadata is actual only in MySQL<=5.6 2023-07-25 22:52:58 +02:00
USAGE.md Update code and CVEs 2023-07-06 08:19:29 +02:00
Anurag's GitHub stats
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
  • A MySQL server installation
