enginestats are only populated if tables exist of that type. Look at default_storage_engine if defined to communicate the default storage engine. closes #469 |
| build | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| mtlogo.png | ||
| mysqltuner.png | ||
| README.fr.md | ||
| README.it.md | ||
| README.ru.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
MySQL 8 (partial support, password checks don't work)
MySQL 5.7 (full support)
MySQL 5.6 (full support, no more MySQL support)
MySQL 5.5 (full support, no more MySQL support)
MariaDB 10.5 (full support)
MariaDB 10.4 (full support)
MariaDB 10.3 (full support)
MariaDB 10.2 (full support)
MariaDB 10.1 (full support, no more MySQL support)
MariaDB 10.0 (full support, no more MySQL support)
MariaDB 5.5 (full support, no more MariaDB support)
Percona Server 5.6 (full support)
Percona XtraDB cluster (partial support, no test environment)
Galera replication (partial support, no test environment)
MySQL 3.23, 4.0, 4.1, 5.0, 5.1, 5.5 (partial support - deprecated version)
Windows is not supported at this time (Help wanted !!!!!)
Cloud based is not supported at this time (Help wanted !!!!!)
*** MINIMAL REQUIREMENTS ***
Hi directadmin user!
- Fedora Core 30 / Docker
