Jean-Marie Renouard 5f92d5866c Merge pull request #221 from 0xbsec/update_without_credentials
Update without credentials issue #211
Thanks @0xbsec
2016-06-13 11:03:35 +02:00
INTERNALS.md Update vulnerabilities list 2016-06-10 10:18:21 +02:00
mysqltuner.pl no need to return, just exit 2016-06-11 16:36:59 +00:00
README.md adding minimum privileges request 2016-06-02 16:24:41 +02:00
vulnerabilities.csv Update vulnerabilities list 2016-06-10 10:18:21 +02:00
  • MySQL 5.7 (partial support)
