Jean-Marie Renouard 5fac4cd07d Adding detection of non primary key tables
Adding detection of non InnoDB tables
Adding detection of non utf8 colums
2023-06-22 23:00:28 +02:00
.gitignore Adding detection of non primary key tables 2023-06-22 23:00:28 +02:00
FEATURES.md Laste version with clean FEATURES.md list 2023-06-11 12:09:10 -04:00
INTERNALS.md Update INTERNALS.md 2023-06-19 10:28:55 +02:00
mysqltuner.pl Adding detection of non primary key tables 2023-06-22 23:00:28 +02:00
README.md remove badges 2023-06-22 22:14:14 +02:00
USAGE.md Updates doc and CVE 2023-06-07 19:29:41 +02:00
Anurag's GitHub stats
  • MariaDB 10.9 (full support)
  • MariaDB 10.8 (full support)
  • MariaDB 10.7 (full support)
  • MariaDB 10.6 (full support)
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
In previous version, --forcemem shoud be set manually, in order to be able to run an MT analysis
  • A MySQL server installation
