2016-03-24 23:56:45 +01:00
.travis.yml Update .travis.yml 2016-01-28 09:29:22 +01:00
INTERNALS.md Advanced dbstat for collation and charset 2016-03-22 17:56:08 +01:00
mysqltuner.pl fix for perl 5.10 and 5.8 2016-03-24 23:56:45 +01:00
README.md Update README.md 2016-01-27 19:18:39 +01:00
USAGE.md Update vulnerabilities list 2016-02-24 19:52:26 +01:00
  • MySQL 5.7 (partial support)
  • MySQL 5.1 (full support)
