Jean-Marie Renouard 625d2cf668
Merge pull request #534 from grooverdan/travis_new
travis: test all supported versions
2021-01-29 22:22:50 +01:00
build merged 2020-05-02 16:01:37 +02:00
Vagrant Removing windows end of lines 2020-05-04 11:01:34 +02:00
.travis.yml travis: docker test all versions 2021-01-29 08:19:18 +11:00
mysqltuner.pl Merge pull request #535 from grooverdan/snap 2021-01-28 18:21:43 +01:00
README.md supported version: +mariadb-10.5, eol mysql-5.6, mariadb-10.[01] 2021-01-27 17:34:02 +11:00
USAGE.md Update USAGE.md 2020-09-15 15:26:15 +02:00
vulnerabilities.csv local commit 2020-05-02 15:56:26 +02:00
  • MySQL 5.6 (full support, no more MySQL support)
  • MariaDB 10.2 (full support)
  • MariaDB 10.1 (full support, no more MySQL support)
  • MariaDB 10.0 (full support, no more MySQL support)
*** MINIMAL REQUIREMENTS ***
