Jean-Marie RENOUARD 645e034efd Update Vulnerabilities list
Indenting mysqltuner
Update Usage information
2021-08-25 12:03:29 +02:00
.github/workflows Create exec.yml 2021-07-05 08:45:01 +02:00
build some aliases 2021-05-03 10:12:00 +00:00
Vagrant Removing windows end of lines 2020-05-04 11:01:34 +02:00
.travis.yml travis: add percona supported versions 2021-02-01 15:11:34 +11:00
mysqltuner.pl Update Vulnerabilities list 2021-08-25 12:01:28 +02:00
README.md failed to execute: SHOW SLAVE HOSTS #553 2021-07-02 16:44:11 +02:00
USAGE.md Update Vulnerabilities list 2021-08-25 12:01:28 +02:00
vulnerabilities.csv Update Vulnerabilities list 2021-08-25 12:03:29 +02:00
  • MySQL 5.6 (full support, no more MySQL support)
  • MariaDB 10.2 (full support)
  • MariaDB 10.1 (full support, no more MariaDB support)
  • MariaDB 10.0 (full support, no more MariaDB support)
*** MINIMAL REQUIREMENTS ***
Question: What's minimum privileges needed by a specific mysqltuner user in database for MySQL 8 or MariaDB 10.5 ?
    mysql>GRANT SELECT, PROCESS,EXECUTE, REPLICA MONITOR,SHOW DATABASES,SHOW VIEW ON *.* TO 'mysqltuner'@'localhost' identified by pwd1234;
