Data::Dumper is in core sice Perl 5.005, so set a minimum Perl dependency and always load Data::Dumper. |
| build | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| README.ru.md | ||
| template_example.tpl | ||
| USAGE.md | ||
- MySQL 5.7 (partial support)
- MySQL 5.6 (full support)
- MariaDB 10.0 (full support)
- MySQL 5.5 (full support)
- MySQL 5.1 (full support)
