Jean-Marie RENOUARD 67b91966e0 Issue #96
2015-07-20 09:57:04 +02:00
misc Documenting a bit 2015-06-21 16:09:00 -04:00
CONTRIBUTING.md Adding a small CONTRIBUTING file 2015-06-16 15:20:36 +02:00
mysqltuner.pl Issue #96 2015-07-20 09:57:04 +02:00
README.md Update README.md 2015-07-15 18:09:28 +02:00
  • MySQL 5.5 (partial support)
  • MySQL 5.6 (partial support)
  • MySQL 6.0 (partial support)
* OS and OS version
* Exact MySQL version
* The full text of the error
