Igor Urazov 6ffa2b7a55 Don't hardcode perl path in shebang
Use universal way of determining current default version of perl. Useful when perl is installed at /usr/bin/local or activated via perlbrew. See http://perlbrew.pl/Dealing-with-shebangs.html for more details.
2014-07-14 15:07:25 +03:00
mysqltuner.pl Don't hardcode perl path in shebang 2014-07-14 15:07:25 +03:00
README.md Converted README from text to Markdown. 2014-02-21 10:52:51 -06:00
  • MySQL 6.0 (partial support)
wget mysqltuner.pl
* OS and OS version
* Exact MySQL version
* The full text of the error
