2016-08-24 00:21:18 +02:00
INTERNALS.md Update INTERNALS.md 2016-07-07 09:49:29 +02:00
mysqltuner.pl Fix SQL string concatenation in capitalization during password test 2016-08-24 00:21:18 +02:00
README.md Update README.md 2016-08-18 09:20:49 +02:00
vulnerabilities.csv Update vulnerability list 2016-08-08 17:16:07 +02:00
  • MySQL 5.7 (partial support)
