Jean-Marie Renouard 7082cbc678 Merge pull request #281 from mrqwer88/fix_in_log_file_recommandations
Fix in log file recommandations
2016-12-07 15:18:49 +01:00
mysqltuner.pl fix code style in log_file_recommandations 2016-12-07 16:31:51 +03:00
README.md Fix typos 2016-11-05 14:27:54 +00:00
vulnerabilities.csv Update vulnerabilities list 2016-11-28 17:52:13 +01:00
MySQLTuner is maintained and indicator collect is increasing week after week supporting a lot of configuration such as Galera Cluster, TokuDB,        Performance schema, Linux OS metrics, InnoDB, MyISAM, Aria, ...
