2015-07-01 16:27:57 +02:00
build rename build rpm script 2015-06-19 11:37:16 +02:00
CONTRIBUTING.md Adding a small CONTRIBUTING file 2015-06-16 15:20:36 +02:00
mysqltuner.pl Adding preconisations on binlog cache and Aborted connections 2015-07-01 16:27:57 +02:00
README.md README format errorswq 2015-06-16 15:45:34 +02:00
USAGE.md Bug fixes with POD documnetation 2015-07-01 13:39:16 +02:00
  • MySQL 5.5 (partial support)
  • MySQL 5.6 (partial support)
  • MySQL 6.0 (partial support)
* OS and OS version
* Exact MySQL version
* The full text of the error
