Jean-Marie Renouard 763ba10872
Merge pull request #787 from devenbj/MariaDB-Version-Updates
Update Versions for MariaDB
2024-07-15 23:34:08 +02:00
build Last updates for MySQLTuner getting is own Docker images jmrenouard/mysqltuner 2024-07-15 23:21:21 +02:00
.dockerignore Last updates for MySQLTuner getting is own Docker images jmrenouard/mysqltuner 2024-07-15 23:21:21 +02:00
.gitignore Last updates for MySQLTuner getting is own Docker images jmrenouard/mysqltuner 2024-07-15 23:21:21 +02:00
CONTRIBUTING.md Fix the fork link 2024-04-24 00:06:25 +02:00
CURRENT_VERSION.txt Bug fix on makefile 2024-07-15 23:32:39 +02:00
Dockerfile Last updates for MySQLTuner getting is own Docker images jmrenouard/mysqltuner 2024-07-15 23:21:21 +02:00
Makefile Bug fix on makefile 2024-07-15 23:32:39 +02:00
mysqltuner.pl Merge pull request #787 from devenbj/MariaDB-Version-Updates 2024-07-15 23:34:08 +02:00
README.fr.md chore: remove travis config 2024-02-10 10:14:02 +01:00
README.it.md chore: remove travis config 2024-02-10 10:14:02 +01:00
README.md Update README.md, remove double 'by default' in some sentences. 2024-07-08 23:30:46 +03:00
README.ru.md Merge pull request #769 from chenrui333/remove-travis-refs 2024-02-12 13:07:45 +01:00
slim.report.json Last updates for MySQLTuner getting is own Docker images jmrenouard/mysqltuner 2024-07-15 23:21:21 +02:00
USAGE.md Generate 2.5.4 sub version at 2024-07-15T22:42:31+02:00 2024-07-15 22:42:31 +02:00
vulnerabilities.csv Generate CVE list at 2024-02-06T17:59:02+01:00 2024-02-06 18:00:04 +01:00
Anurag's GitHub stats
Test result are available here:
  • MySQL 8.0, 8.2, 8.3 (full support)
  • Percona Server 8.0, 8.2, 8.3 (full support)
  • MariaDB 10.4, 10.5, 10.6, 10.11, 11.0, 11.1, 11.2 (full support)
  • MySQL 8.1 (not supported, deprecated version)
  • Percona Server 5.7 (not supported, deprecated version)
  • MySQL 5.7 (not supported, deprecated version)
  • MariaDB 10.7, 10.8, 10.9, 10.10 (not supported, deprecated version)
  • MariaDB 10.3 and earlier (not supported, deprecated version)
  • RockDB is not maintained anymore
  • TokuDB is not maintained anymore
  • XtraDB is not maintained anymore
  • Unrestricted read access to the MySQL server OS root access recommended for MySQL < 5.1
Sysschema is installed by default under MySQL 5.7 and MySQL 8 from Oracle. By default, on MySQL 5.6/5.7/8, performance schema is enabled. For previous MySQL 5.6 version, you can follow this command to create a new database sys containing very useful view on Performance schema:
cd mariadb-sys-master
Performance schema setup
By default, on MariaDB, performance schema is disabled (MariaDB<10.6).
max-digest-length=2048
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
  • A MySQL server installation
 SHOW DATABASES,SHOW VIEW
 ON *.*
