Add query cache type verification MySQL >= 5.6.8 has query_cache_type OFF by default. It will disables the entire cache. http://dev.mysql.com/doc/refman/5.6/en/server-system-variables.html#sysvar_query_cache_type |
- MySQL 5.4 (not fully tested, partially supported)
- MySQL 6.0 (partial support)
- MariaDB 10.x (partial support)
- Windows is not supported at this time
- Unrestricted read access to the MySQL server (OS root access recommended for MySQL < 5.0)
wget mysqltuner.pl
* OS and OS version
* Exact MySQL version
* The full text of the error
