| .github/workflows | ||
| build | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| mtlogo.png | ||
| mysqltuner.png | ||
| README.fr.md | ||
| README.it.md | ||
| README.ru.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
MySQL 5.7 (full support)
MySQL 5.6 (full support, no more MySQL support)
MySQL 5.5 (full support, no more MySQL support)
MariaDB 10.5 (full support)
MariaDB 10.4 (full support)
MariaDB 10.3 (full support)
MariaDB 10.2 (full support)
MariaDB 10.1 (full support, no more MariaDB support)
MariaDB 10.0 (full support, no more MariaDB support)
MariaDB 5.5 (full support, no more MariaDB support)
Percona Server 5.6 (full support)
Percona XtraDB cluster (partial support, no test environment)
Galera replication (partial support, no test environment)
MySQL 3.23, 4.0, 4.1, 5.0, 5.1 (partial support - deprecated version)
Windows is not supported at this time (Help wanted !!!!!)
Cloud based is not supported at this time (Help wanted !!!!!)
*** MINIMAL REQUIREMENTS ***
Hi directadmin user!
Question: What's minimum privileges needed by a specific mysqltuner user in database for MySQL 8 or MariaDB 10.5 ?
mysql>GRANT SELECT, PROCESS,EXECUTE, REPLICA MONITOR,SHOW DATABASES,SHOW VIEW ON *.* TO 'mysqltuner'@'localhost' identified by pwd1234;
- Fedora Core 30 / Docker
- Fork this Github project
- Make a new branch
- Make your changes
- Push it back to your repo
