2023-05-11 17:21:01 +02:00
.github/workflows Renaning Branch for MAriaDB Examples 2023-03-23 16:34:58 +00:00
CODE_OF_CONDUCT.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
CONTRIBUTING.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
INTERNALS.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
mysqltuner.pl Update mysqltuner.pl 2023-05-11 17:21:01 +02:00
README.it.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
README.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
USAGE.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
vulnerabilities.csv Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
  • MariaDB 10.9 (full support)
  • MariaDB 10.8 (full support)
  • MariaDB 10.7 (full support)
  • MariaDB 10.6 (full support)
  • A MySQL server installation
