2016-04-18 11:07:05 +02:00
INTERNALS.md Update Internals checks documentation 2016-04-05 09:18:10 -04:00
mysqltuner.pl #187 enforce control over P_S activation 2016-04-18 11:07:05 +02:00
vulnerabilities.csv Revert "Revert "Update CVE list"" 2016-03-23 12:19:54 +01:00
  • MySQL 5.7 (partial support)
  • MySQL 5.1 (full support)
