Jean-Marie Renouard 835a181232
Merge pull request #727 from major/renovate/actions-checkout-4.x
Update actions/checkout action to v4
2023-09-09 12:25:01 +02:00
Makefile Last updates 2023-09-09 12:08:45 +02:00
mysqltuner.pl Join Buffer Size recommendation Link Broken #722 2023-09-09 12:22:32 +02:00
README.md clarify that innodb_stats_on_metadata is actual only in MySQL<=5.6 2023-07-25 22:52:58 +02:00
README.ru.md clarify that innodb_stats_on_metadata is actual only in MySQL<=5.6 2023-07-25 22:52:58 +02:00
USAGE.md Generate 2.2.12 sub version at 2023-09-09T12:07:44+02:00 2023-09-09 12:07:53 +02:00
vulnerabilities.csv Last vulnerabilites list 2023-09-09 08:25:53 +02:00
Anurag's GitHub stats
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
  • A MySQL server installation
