MATSUU Takuto 85393335ce Fixed to work with MySQL 5.0.
information_schema.engines table was added in MySQL 5.1.5.
https://dev.mysql.com/doc/refman/5.1/en/engines-table.html
2014-02-24 21:31:20 +09:00
mysqltuner.pl Fixed to work with MySQL 5.0. 2014-02-24 21:31:20 +09:00
README.md Converted README from text to Markdown. 2014-02-21 10:52:51 -06:00
  • MySQL 6.0 (partial support)
wget mysqltuner.pl
* OS and OS version
* Exact MySQL version
* The full text of the error
