2018-09-23 06:31:24 +00:00
build Ticket #383 Minor accessing undefined variable bug to fix eventually 2018-06-29 12:16:30 +02:00
.travis.yml Try to use mysql 8.0 2018-09-23 06:31:24 +00:00
bashrc Update README with performance tips 2018-09-22 05:04:28 +00:00
INTERNALS.md Fixing important performance issue during collecting metrics 2018-09-20 13:11:34 +00:00
mysqltuner.pl ignore galera check when wsrep_on = 0 #353 2018-09-20 14:34:07 +00:00
README.md Adding link to travis result 2018-09-22 07:37:01 +00:00
USAGE.md New option tbstat 2018-09-20 12:51:07 +00:00
Test result are avalaible here: Travis CI/MySQLTuner-perl
  • MariaDB 10.2 (full support)
