Jean-Marie Renouard 87154ff511 Merge pull request #174 from zhil/master
Update README.md
2016-03-29 13:57:40 +02:00
.travis.yml Update .travis.yml 2016-01-28 09:29:22 +01:00
INTERNALS.md Advanced dbstat for collation and charset 2016-03-22 17:56:08 +01:00
mysqltuner.pl Fix grammar 2016-03-29 01:27:41 +02:00
USAGE.md Update vulnerabilities list 2016-02-24 19:52:26 +01:00
  • MySQL 5.7 (partial support)
  • MySQL 5.1 (full support)
