Jean-Marie Renouard 8816ff009d
Update INTERNALS.md
2019-01-07 10:58:30 +01:00
build Removing employee db for repository 2018-11-25 07:23:34 +00:00
.travis.yml Removing employee db for repository 2018-11-25 07:18:45 +00:00
INTERNALS.md Update INTERNALS.md 2019-01-07 10:58:30 +01:00
mysqltuner.pl A bit of work on the html report template 2018-11-30 13:06:49 +00:00
README.md Fixed spelling of available. 2018-11-26 13:49:38 -08:00
runAudit.sh New script for running remote audit and generate HTML report 2018-09-24 16:12:40 +02:00
txt2html.pl New script for running remote audit and generate HTML report 2018-09-24 16:12:40 +02:00
USAGE.md Last modification related to options 2018-11-26 12:57:11 +00:00
  • MariaDB 10.2 (full support)
curl "https://codeload.github.com/good-dba/mariadb-sys/zip/master" > mariadb-sys.zip
cd mariadb-sys/
mysql -u root -p < ./mariadb_sys_install.sql
