2015-09-07 11:29:20 +02:00
build bug fixes on RPM generation 2015-08-31 18:10:54 +02:00
.gitignore bug fixes on RPM generation 2015-08-31 18:10:54 +02:00
.travis.yml remove perl-5.6 from tests 2015-08-23 18:12:57 +10:00
CONTRIBUTING.md Update CONTRIBUTING.md 2015-08-24 11:24:04 +02:00
INTERNALS.md Update INTERNALS.md 2015-08-19 16:20:38 +02:00
mysqltuner.pl Issue #124: bug fix with noask password handling... from issue #110 patch 2015-09-07 11:29:20 +02:00
README.md Update README.md 2015-08-27 12:09:53 +02:00
template_example.tpl Adding a HTML report system with a default template engine based on Text::Template 2015-08-26 15:23:19 +02:00
Build Status - Master
  • MySQL 5.7 (partial support)
  • MySQL 5.1 (full support)
