| build | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| mysqltuner.png | ||
| README.ru.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
- MySQL 5.7 (partial support)
- MySQL 5.6 (full support)
- MySQL 5.5 (full support)
- MariaDB 10.0 (full support)
Question: How to use mysqltuner from remote host ?
You will still have to connect like a mysql client:
--host Connect to a remote host to perform tests (default: localhost)
--socket Use a different socket for a local connection
--port Port to use for connection (default: 3306)
--user Username to use for authentication
--pass Password to use for authentication
--forcemem Amount of RAM installed in megabytes
--forceswap Amount of swap memory configured in megabytes
You may have to contact your remote SysAdmin to ask how much RAM and swap you have
--skipsize Don't enumerate tables and their types/sizes (default: on) (Recommended for servers with many tables)
- Fedora Core 23 / MySQL 5.6
- Fedora Core 23 / MySQL 5.7
- vagrant up
- Start vagrant
- vagrant up
