| .github/workflows | ||
| build | ||
| examples/github/result | ||
| templates | ||
| test_db@d01cb62fcf | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| mtlogo.png | ||
| mysqltuner.png | ||
| README.fr.md | ||
| README.it.md | ||
| README.ru.md | ||
| renovate.json | ||
| SECURITY.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
MySQL 5.7 (full support)
MariaDB 10.11 (full support)
MariaDB 10.10 (full support)
MariaDB 10.9 (full support)
MariaDB 10.8 (full support)
MariaDB 10.7 (full support)
MariaDB 10.6 (full support)
MariaDB 10.5 (full support)
MariaDB 10.4 (full support)
MariaDB 10.3 (full support)
RockDB
Archive
Spider
ColummStore
TokuDB
XtraDB
Connect
Hi directadmin user!
- A MySQL server installation
- Fedora Core 30 / Docker
- Fork this Github project
- Make a new branch
- Make your changes
- Push it back to your repo
